panic mode
- Joined Oct 10, 2011
- 5,153
yup but that is much smaller and harder to hand solder than SOIC-8. i am expecting that someone used to DIP will not like that jump ;-)
Sort of. Using an ADC.Are we forgetting that the TS is trying to produce a DAC?
sorry, bad math. aiming for .001 volt resolution across 4 or 5 volt range.0.1% is equivalent to 10-bit (1/1024=~ 0.1%)
that is a far cry from 16-bit.
what is the application?
This is really good to know - but I plan to use IC sockets.I find 1.27mm pitch surface mount much easier to repair than through hole, especially plated through holes. Far too difficult to desolder compared to heating it with hot air and lifting it off.
0.635mm pitch is about on a par.
0.5mm pitch and I would prefer struggling with getting pins out of throughplated holes
What's your goto marketplace for finding dsPics? I looked that one up by model number and I'm not seeing the DAC on the datasheet but now I really want to find one. A microcontroller like that would be 100% ideal for my use case.i like that, it would need to be EP variant such as PC33EP32GP502ISP and it is very nicely priced.
That’s the one.Found this on Microchip's site:
DSPIC33FJ64GP802-I/SP
https://www.microchip.com/en-us/product/dsPIC33FJ64GP802#product-purchase
it's available in spdip!
Well, it's a Eurorack format control voltage sequencer for audio synthesis use. It will have 8 rotary encoders (quadrature) and a series of momentary switches connected via interrupt-capable IO expanders. It will also have a TFT screen that has a built-in SD card slot for storage.That’s the one.
The next question is where is the data coming from?
I tried! Apparently my account is either too fresh or I'm not cool enough for free samples. I'll probably just get it via Digikey when I next have that sweet sweet project cash.Microchip, TI, ST etc are all awesome... you should also be able to get free samples.
That makes sense! Might have a family member I know help me with that.to qualify for sample programs one usually must register using "official" email like school or work - not the web mails like Gmail, hotmail, Yahoo mail.
MPLAB the free version of their C compiler.What's everyone using for PIC programming? Is there a place I can go to find compatibility with various PIC ICs? I assume I'll be using MPLAB. I'm a hobbyist C++ programmer so I think I'll be fine on the software side.
Just wanted to say again - this community has been so freakin helpful. Thank you!
MPLabX is the IDE. XC8 is the compiler.MPLAB the free version of their C compiler.
I imagine I'll be using MPLabX with XC16. I like cross-platform software.MPLabX is the IDE. XC8 is the compiler.
Edit: XC8, XC16, XC32, XC-DSC
