AD9283 How to use AIN /
majd-ghadab
Joined Dec 25, 2012
23
Hello everyone,
i have a question, but before i asked, i tried to search for a solution or application note but i couldn't find. anyway, i would like to use this chip AD9283 and my question is, can i connect the AIN/ to ground and use the AIN as input to ground when my signal is between 0-3.3 V?
Thanks in Advance.
majd-ghadab
Joined Dec 25, 2012
23
Hello, I found the solution : it was written in Datasheet. I should give more time reading it..
Analog Input for ADC (Can Be Left Open if Operating in Single-Ended Mode, but Rec
ommend Connection to a 0.1 µF Capacitor and a 25 Ω Resistor in Series to Ground for
Better Input Matching)
TeeKay6
Joined Apr 20, 2019
573
Thank you for letting all know that you found a solution and no further help is needed (at this time).
