I have a question regarding ACS732KLATR-65AB. I have simulated the current sensor IC ACS732KLATR-65AB in LTspice whose current sensing range is -65A to 65A, sensitivity is 30mV/A and Vcc is 5V. When I run the simulation, it gives fault signal for the input current above 32.5A. How to model correctly for +/-65A.
How to feed the IC that IRpMAX is +/-65A?
Jeya
Jeya
