ac to dc power supply
carolina new be
Joined Mar 7, 2020
7
I am looking to build a power supply to operate an old radiosonde aka weather balloon
it requires 120 volt ac input and 3 dc outputs which are
1.5 volts and 6 volts dc with a common ground
115 volts with its own ground
any estimates on how much this cost to build ? I can build the housing
Thank You
This is my first posting in this forum
c n b
wayneh
Joined Sep 9, 2010
18,184
The low voltages are easy. How “clean” and regulated does the 115VDC need to be? Simply rectifying the AC would be close to 115V after the diode drops. The peaks will be higher, and the valleys far lower, but maybe that’s ok?
carolina new be
Joined Mar 7, 2020
7
I will half to get a battery pack open it and water activate it and when it gets up to
the operating voltage measure the current on each of the 3 outputs
carolina new be
Joined Mar 7, 2020
7
I had an open water activated battery but it had absorbed some of the moisture and the battery
did not produce a full voltage So I gotta order another battery . When it comes in I will check the current
and report back
CNB
