I've been doing some audio recording on my laptop (a Dell Inspiron 6400) at home. For a long time now, I've known that I get humm when I run off wall power, and none when I run off battery, so I've always done my recording on battery power. My battery is getting pretty old now, and it's hard to get anything more than about 45 minutes of recording time out of it per charge. I'd like to make some modifications so that I can record noise-free while running on wall power.
I did a spectral analysis of the background noise while running on wall power and battery.
The analysis for running on wall-power shows the expected peak at 60Hz, as well as harmonics at 120, 180, 240...
Battery power shows no such spikes
What is the best (and safest) way to filter out the 60Hz while using my laptop transformer? Should I add a large electrolytic shunt capacitor somewhere? Is it better to modify the transformer or the motherboard?
Maybe there's a better solution?
