What is the best topology to make an AC and DC regenerative electronic load?
Exactly so, as given in my last example above.An electronic load is fed by an electric outlet. It produces a current to test some other device. But if this device under test is an energy meter, for example, the electronic load would work as a linear amplifier, burning energy in form of heat. Imagine we can return this energy to the outlet instead burn it. This is what I mean by the regenerative electronic load.
That's effectively the EV version, though with a DC feed. Sometimes you see top of the range Variable Frequency Drives (VFD) for machinery (lathes, etc.) do this, though most just use a braking resistor 'cos its cheap.this may be what you are talking about:
The active rectifier acts both as as a full wave rectifier when "motoring" and as as inverter when the motor is "generating" to return energy to the mains supply.
regenerative braking (in case the mains can take the reverse flow with leading power factor without causing an overvoltage) has been very successfully used in operations like large mineral conveyor belts in mines, lots of energy returned to the gridThat's effectively the EV version, though with a DC feed. Sometimes you see top of the range Variable Frequency Drives (VFD) for machinery (lathes, etc.) do this, though most just use a braking resistor 'cos its cheap.
Also:
I see.
You need a grid-tie inverter such as Victron's MultiPlus, which you can program to take a certain amount of current from the battery and return it to the grid.
I think that the system will need to have a real battery to keep the system stable but you should be able to make the battery look bigger than it actually is by selecting the amount it returns to the grid.
Victron's products are generally far too clever for their own good. You won't fool them into thinking there is a battery when there is a capacitor, but the idea is valid.seems a good idea to test the idea, if it works I would change the small battery for a capacitor, and project my own inverter, that will be fast enough to turn possible using that capacitor.
When I asked this is because I was thinking about making my own inverter to simulate the battery or any other type of load, but my inverter would return the energy to the outlet instead transform it in heat or in movement. But your idea of using a shelf inverter could save me a lot of time.Victron's products are generally far too clever for their own good. You won't fool them into thinking there is a battery when there is a capacitor, but the idea is valid.
If you can find a grid-tie inverter with programmable input current that's not quite so smart you might be on to something.
A | DC Shunt wound motor flashover | Power Electronics | 7 | |
K | Cannot change 90 Mhz FM receiver (SRR) to 16 MHz FM | Wireless & RF Design | 34 | |
A | Regenerative motor drive | Power Electronics | 2 | |
F | automatic dpdt switch for 2 regenerative blowers | General Electronics Chat | 9 | |
C | Regenerative braking efficiency | General Science, Physics & Math | 0 |
