About Light Load Disadvantage of Resonance Converters
Trunke10
Joined Apr 1, 2022
Recently I've bee studying Robert W. Erickson's Fundamentals of Power Electronics. At the chapter of resonant conversion, the book says that "The circulating tank currents are independent, or weakly dependent on, the load current, and lead to poor efficiency at light load, which is confusing for me. According to my understanding, the effective resistance Re of the dc-dc converter increases at light load. Therefore, the peak magnitude of the tank current would decrease, which conflicts to what the author states. Could someone tell me where I'm wrong?
Papabravo
Joined Feb 24, 2006
22,115
The efficiency of a converter is determined by the power delivered to the load divided by the power consumed from the source. For a fixed amount of input power, the efficiency will decrease as the power to the load is reduced.
Trunke10
Joined Apr 1, 2022
First of all, thank you for your reply. I agree of what you said, efficiency is load power/source power. But, in light load conditions wouldn't input current (input power) decrease in resonant converters?
Ian0
Joined Aug 7, 2020
13,306
Yes, but not as much as it should. The circulating current in the resonant circuit remains, and it must pass through some resistance, creating loss.
Trunke10
Joined Apr 1, 2022
Thanks a lot. I think I understand what you're saying. Since we operate at frequencies slightly above/below resonant frequency, we get an inductive/capacitive load. Therefore, input impedance of the tank doesn't act "purely resistive", which implies that input current wouldn't decrease "as much as it should". Am I correct?
Ian0
Joined Aug 7, 2020
13,306
The resonant circuit is constantly transferring energy from the capacitors to the inductors and back again. Think of it like a flywheel. You put energy in and you take energy out. But if you stop taking energy out of the system you still have to put some energy in to keep the flywheel spinning.
You don’t have to put that energy in to a non-resonant system. So why not simply use a non-resonant converter? Because there are other losses associated with the non-resonant converter, and a high load those losses are higher than the losses from the resonant converter.
johnyradio
Joined Oct 26, 2012
615
Let's say your resonant frequency is 100 kHz. Doesn't that mean you're putting energy into the circuit 100 K times per second?
Say your resonant frequency is 100 kHz, and your load is an audio amplifier. Say the audio you're passing through the amplifier is a 1 kHz sine wave. So you're putting energy into the circuit 100 times per audio waveform, right? Will the converter efficiency vary during a single music waveform, and drop during the trough of the audio waveform?
If your audio amplitude drops momentarily, will converter efficiency drop at the same time?
