about 555 and LDR
ertiexd125
Joined Jul 4, 2010
16
I'm trying to use a 555 and LDR. The idea will be like this when the LDR sense darkness and the darkness will remain for a long time. The Led should On and will remain on until the preferred time and it will not turn on unless the LDR will sense light and then dark again. Can I get these result by using an LDR for the input trigger and 555 for the delay timer? pls help.
Wendy
Joined Mar 24, 2008
23,862
Yeah, you can do that. It would probably be simpler to use a 555 connected to the the LDR and feed a second 555 that is the timer.
The first 555 converts the light signal into something digital.
