AA battery not powering DC radial cooling fan
Shrek17
Joined Oct 1, 2024
5
AA battery connected to step up modular (5v) can power a 5V DC cooling fan BUT
if a DC centrifugal radial 5V cooling fan is connected then its not working
The DC radial fan works fine with 5V mobile charger
Shrek17
Joined Oct 1, 2024
5
It would appear the radial takes more current than the other cooling fan.
Images of them don't tell us much.
Do you have the current requirement specs for both?
The standard fan 4010 with mobile charger (5v) OR 3 AA batteries (4.5) shows 90mA BUT with 5v step up module it shows 550mA. This fan works fine.
The DC radial fan with mobile charger OR 3 AA batteries (4.5v) shows 130mA BUT with 5v step up module it just jerks and does not spin. While at that moment of minor spin the current reading shows 770mA.
38,819
The radial fan appears to require more than 770mA to start.
What is the output current rating of the 5V step-up module?
Shrek17
Joined Oct 1, 2024
5
with 1 AA (1.5v) battery the step up module output shows 44mA
with 2 AA (3v) battery the step up module output shows 1.03A
schmitt trigger
Joined Jul 12, 2010
2,235
The DC radial fan’s ACTUAL current consumption is….
Hmmmm.
My crystal ball is having poor Wifi reception.
To the TS: can you please provide the value as read on the fan’s label.
38,819
Love this game of 20 questions. :rolleyes:
So what is the 5V module's output voltage when it is delivering 770mA to the radial fan?
BobTPH
Joined Jun 5, 2013
11,653
There is no mystery here. To boost from 1.5V to 5V at 770mA you need 2.5A if it was perfectly efficient. That is simply too much current for the AA to provide and we know the motor not start at that current.
Jon Chandler
Joined Jun 12, 2008
1,645
This is EXACTLY WHAT HAPPENS when you attempt to operate a motor that draws too much current from a switching power supply. The motor starts to spin, then the switcher shuts down because the current draw is too great. Then the process repeats.
The radial fan rotor has more mass and interia than the rotor of the axial fan, so it makes sense that the starting current is higher. The starting current is the key point.
Sorry this does not conform to your desires.
Ya’akov
Joined Jan 27, 2019
10,300
There is really no ambiguity. Your boost converter can supply enough current to start the fan. The fix is to get a new one that can do the job. But there is a mysterious part—why are you trying to run these fans from AA cells?
wraujr
Joined Jun 28, 2022
265
Quick test, put 2, 3, or 4 AA batteries in parallel. As mentioned, you may need 2.5A input and due to internal resistance of battery the input voltage is dropping to the DC/DC causing it to shut down. Then with load removed, voltage rises and DC/DC turns back on, etc.
BTW, pictures are cool, but real designers work from datasheets and that requires part numbers. How about part numbers for fans and DC/DC?
