Hi Again,
I now have my first circuit on my bread board with a motor's on/off controlled by an NPN transistor.
The motor is of unknown make / model. It is small and was in a box full of odd bits.
I bought the following transistor:
http://www.datasheetcatalog.org/datasheet/motorola/BD237.pdf
I made it a medium size one so it would fit in my bread board and bought it from maplin as they are down the road. The thought process in buying it was:
a) make it largeish to withstand any abuse?
b) small enough so it would fit in my bread board.
Not a lot of thought but the range they had was small! I'm driving the emitter to base with 1.2v (rechargable AA) and the motor supply is via a 4.5v 1200ma uniross power adapter
I now want to put in a potentiometer to allow me to vary the speed of the motor. I'm sure there are better ways.
1) My primary question is how do I go about selecting a variable resister for the transister
I need to learn how to 'read' the data sheets - is there a reference I can refer to?
2) My second qurstion is generally about choosing resisters. I understand that ~0.7V is required between emitter and base to open the gate. So... bare with me.....if that is the case, for the emiiter / base circuit we have a resistance. Therefore when combined with the protection resister we have a voltage divider? I measured the emitter to base resistance of my transister and there is some resistance ~30 MOhms (about as much as through my hands).
So here are my assumptions, if 0.7V is required to allow current to flow through a PN junction then there is internal resistance. I assume when the 0.7v is reached (and before) the resistance decreases and current increases. So.....it's getting long this.... since resistance goes down but I still wish to maintain ~0.7v how do I choose the protection resister ?
reference:
http://www.allaboutcircuits.com/vol_3/chpt_2/6.html
noteably
Once again, thanks in advance for any replies.
Charlie
reference:
noteably
Charlie
