A real working driver is needed for signal from 74AC14 to voltage multiplier
Rhou
Joined Feb 8, 2025
7
A real working driver is needed for signal from 74AC14 to voltage multiplier via drivier.
Supply 5 Volts from 278R05. on one element 74AC14 create generator 583Khz.
Next 5 triggers connect in paralel for more current value.
output signal need connect to driver (2 or 4 mosfets) on IRF7319 (P-channel and N-channel in one package).
driver connect to voltage multiplier x6 VCC. Next connect to stabilizer L7812, and need output about 50mA current.
need driver circuit witch IRF7319.
Not working driver sample I attach:
schmitt trigger
Joined Jul 12, 2010
2,194
Your circuit is still incomplete. While we may guess at your intention, the incomplete circuit prevents us from suggesting anything other than only speculations.
But if you want to understand Mosfet gate drive ICs, please read the following:
https://www.allaboutcircuits.com/te...-new-gate-driver-ic-from-diodes-incorporated/
EDIT: I have re-read your first post, and there you mentioned that you would like to multiply the 5 volt input 6 times, and then regulate it down to 12 volts.
Why would you even want to do that in the first place?
Rhou
Joined Feb 8, 2025
7
I need get 12 volts and 50mA from 5 volts supply.
Irving
Joined Jan 30, 2016
5,195
Works but only 50% efficient and generates peak pulse currents of 8A+ on 5v supply. And you need 8-stage to get 3v headroom for a 7812. Use a 1W pre-packaged DC-DC converter instead, or if you want to roll your own, there are many sub-$1 chips eg TI LM2735, see below.
LM2735 example
Rhou
Joined Feb 8, 2025
7
LM2735 example
yes, I know about dc/dc converters. but need create with irf7319. need very simple : how connect this 4 mosfets for like by multipier for bigest current. without driver, only on ic 74ac14 I get about 2mA. need driver.
sparky 1
Joined Nov 3, 2018
1,218
The boost converter current is from the inductor's magnetic field,
In this video shows output fix for the MT3608. fast forward video to 10:25
if current limiting is needed then the duty cycle can help.
A 7414 used to make a voltage tripler with input 5V, RC for 583kHz is 470pF and 1.6K, 15V regulated to 12Vdc@20mA
an LC pair for 583kHz is 10uF and 7.46nF used to tame the noise discussed in an earlier video.
In the video he tries more complex and expensive converters repairing one he uses the tweezers alot but in the end
he settles for the cheap one, he understands the noise is less and the price is less.
0ri0n
Joined Jan 7, 2025
186
A Dickson charge pump is shown below. Needs a complementary drive, in this case without resorting to non-overlapping clocks. Clock frequency is 100kHz. Efficiency is good with low average transistor dissipation. Using integrated MOSFET drivers instead of discrete transistors would simplify things.
