A quick way to check if high powered pulsed lasers are working.
thescientist1064
Joined Jul 7, 2024
Hey everyone, I am fairly new to electronics and am trying to wire a high power pulsed laser diode to a laser driver. I am noticing that no current is flowing through my driver despite having wired my diode in forward and reverse (i.e. both polarities). I am concerned if my pulsed diodes are dead on arrival and would like to know how I can check this. I have attached the diode & driver information below! Thanks!
Pulsed Diode: https://ams-osram.com/products/lasers/ir-lasers-eel/osram-metal-can-to56-spl-ul90at03
Driver: https://www.picolas.de/en/produkt/ldp-v-240-100-v3-3/
ericgibbs
Joined Jan 29, 2010
21,571
Hi 1064,
How are you measuring the Laser diode current?
I guess you are aware that 904nm IR is not visible to the human eye?
Are you wearing the correct protective eye protection while experimenting?
What is the application?
E
Alec_t
Joined Sep 17, 2013
15,156
From the datasheet, the diode's maximum reverse voltage rating is 3V. Did you exceed that? Also, the maximum pulse width rating is 100ns with a 0.1% duty cycle. Did you exceed those ratings?
Welcome to AAC!
35,178
I have a Sony digital camera that I keep handy for this purpose. The CCD array responds to IR. I can see the LED glow on the camera's screen.
Alec_t
Joined Sep 17, 2013
15,156
That linked driver has an output current rating of 40-240A (with no obvious way of setting a lower current), whereas your diode has a maximum current rating of 20A. I agree with MrChips, post #4.
