The LE pin needs a pulldown resistor. 100k to GND would probably work.I wonder how the LE input would behave when the diode's anode is on LOW. Would it be effectively tied on LOW potential?
You're welcome.Many thanks for the explanation on your changes and for the 74HC373
No, it is not "interactive" like that. However, you can show current flow vs time on the plot output by clicking on a component (if it has two leads) or a component lead (if >2 leads).Question about LTSpice - does it show the current flow in the schematic? It is one of the nice things about the current simulator I am using.
