7 Segment LED display problem - air hockey scoreboard
Dodgydave
Joined Jun 22, 2012
11,395
You can narrow it down faster by using a flat blade screwdriver and temporary shorting the C/E pins of the 100 ohms transistors, one by one when the display shows zeros, the faulty segment should light up,
if it does the fault is from the transistor to the chip,
if it doesn't its from the transistor to the display.
chadecoen
Joined Oct 14, 2015
14
Can I get a suggestion on the correct transistor to buy to replace mine? Was looking at amazon but I'm not sure which one is correct. Same with 100 ohm resistors. Any suggestions? Is Amazon even ok to buy from?
BTW, I think I found the culprit?
chadecoen
Joined Oct 14, 2015
14
Thanks AK. I'm in GA. Just outside Atlanta.
And is a 100 ohm resistor a 100 ohm resistor or is there any specifics I should look for?
12,267
There is nothing special about any of the components on this board. Any general purpose resistors, caps, and transistors will work. If you're in a hurry, Radio Shack has a 15-pack of PNP's for $3.50, Catalog #: 2761604.
Or I can mail you some. I got lots.
chadecoen
Joined Oct 14, 2015
14
Thanks again AK. I would imagine anyone who has ever ordered has extra! 100 packs online for a couple bucks, that's crazy affordable. I appreciate it but I think you are right. Prolly easiest to just stop by the Shack today while running around.
Thanks for all of y'alls help with this. Super excited to see if I can rescue it after all is said and done.
chadecoen
Joined Oct 14, 2015
14
Also, if you move on to replace parts, DONT OVER HEAT THE PCB. these boards are not really meant for rework and the copper pads can come loose from the board when heated too much and then you have a real mess. If you don't have one, use a temp controlled soldering pencil and solder wick to remove solder or a good solder sucker/desoldering station (re-work station)
Well I promised an update and despite GopherT's best advise, I really screwed up the traces on the board. Anyone willing to charge me to build it over or fix my mess somehow? It's just too delicate for me. I had high hopes but I think someone with more experience and the proper tools would have better luck. Any ideas? I really appreciate all the help getting me to here everyone.
Chad
chadecoen
Joined Oct 14, 2015
14
Thanks Brevor, GopherT has already re-invented the wheel on this and thinks mine may be similar to his and is willing to check it out. If it doesn't work out I'd be very grateful for your help. THANK YOU!
Chad
rburggraf
Joined Oct 9, 2017
1
I know this thread is over 1 year old, but I think you are my only hope. I bought a Classic Sport 788 Air hockey table with a score board that looks exactly like this thread. The display is dim and has missing display segments. Trouble is they quit making this display in 1999, there are no manuals or anything. If you think you might be able to fix it, I'll pay for your time and parts. There just is no other way for me to get this fixed.
markmannjr
Joined Nov 15, 2024
3
Sorry to necro this old thread but I have this exact same circuit board and it snapped in half. Does anyone know if a replacement part is sold or is this thing so old that is impossible?
