7 segment Display
35,179
ok then how can we display letters separately on different 7 segment display?
If you had six displays you would need six decoders.
Or you can use one decoder and do TDM (time division multiplexing) where each display is enabled for one sixth of the total cycle.
As I commented before, the assignment as given is an unreasonable one for a class just starting off in digital logic.
Orionyx
Joined Jan 19, 2024
25
can you tell which decoder ic we will use to display alphabets?
35,179
That is part of the assignment. There is no decoder IC available. You have to create this yourself.
That is the purpose of the truth table. You don't need a table for all 26 letters of the alphabet. You only need a table for the letters in your name "KAMILAH".
Orionyx
Joined Jan 19, 2024
25
Is this truth table right?
Orionyx
Joined Jan 19, 2024
25
It is not about whether the table is right or wrong. It is about understanding the principles involved. I am not going to check your work for correctness.
Now, for the letters "KAMILAH", how many states are required to display all letters?
7 states are required to display all letters.
dl324
Joined Mar 30, 2015
18,467
Six displays
Go back and talk to your professor. Your name is 7 characters and a 3 second delay between letters doesn't make sense if you have multiple displays. One of you doesn't understand the problem. My money is on the professor because it's his/her problem...
35,179
Explain to your professor that you cannot show "K" and "M" on 7-segment displays.
Ask permission to use another name, such as "ELAYA".
