'-6Vdc to +6Vdc' signal to '0 to 10vdc' signal
saifmalik87
Joined Apr 15, 2013
Hi there,
I was wondering if someone could help me to design a circuit that will take a -6VDC to +6VDC signal and convert it to 0 to 10VDC signal range.
Many thanks.
Regards,
Saif Malik.
BobTPH
Joined Jun 5, 2013
11,678
By signal, I presume you mean it will not have to supply significant current, right? Some people refer to it as a signal even when it needs to provide power.
maanga
Joined Aug 20, 2012
13
Hi there,
Many thanks.
Regards,
Saif Malik.
Use opamp 1 to reduce gain ..output to +/- 5 volts. Use a 10 turn preset.
Use opamp 2 to offset signal by applying -5 volts to negative input.
Recalibrate again opamp 1.
You will need precision +10 volts supply to do the offset.
The power supply must be +/- 15 volts.
Regards.
