Hi
I need a little help with a temp/rh sensor that I bought for a Raspberry Pi with a Widgetlords Pi-SPi-8AI (extension board with analog inputs)
The sensor is a T9602-5-A
In the datasheet it looks like this:
Then, it also says that users can refer to Application Guide AAS-916-127, to find the processes to convert the Pulse Density Modulated (PDM) outputs to analogue outputs.
The whole guide is about 40 pages, but I think that its something like this that I need:
My analog 0-5 VDC (0-6.6) input board supports 12 bit resolution.
I tried to connect the sensor as is, but I was getting values like all over the place... (but a steady 2.06V on the input with a cheap multi meter)
So I guess is that I need a low pass filter to even the signal out.
So my questions is:
Can I just buy a couple of 1600nf capacitors and 10k resistors and the signal would be fine?
1600nf/1,6uf isnt the most popular capacitor on the market. Can I for example use 2.2uf?
Thanks in advance
So my questions is:
Thanks in advance
