its oscillating far past its rated frequency not sure whats wrong with the circuit.
P Thread Starter pager48 Joined Nov 25, 2018 161 Jan 20, 2019 #1 its oscillating far past its rated frequency not sure whats wrong with the circuit. Attachments Draft1-LTSPICE.asc 1.5 KB Views: 13
DickCappels Joined Aug 21, 2008 10,187 Jan 20, 2019 #3 ...and connect the threshold pin to the discharge pin. It would be even better if you add the second resistor as shown in the schematic below.
bertus Joined Apr 5, 2008 22,278 Jan 20, 2019 #5 Hello, Have a look at the hysteretic 555 circuit: 555 Hysteretic Oscillator Bertus
iONic Joined Nov 16, 2007 1,662 Jan 20, 2019 #6 The 33K resistor you have from Threshold pin to V+ should be in between threshold and Pin 3 if this is the circuit you were recreating. But personally, I'd trust bertus and the others!
