555 transitor RGB LED headache
Olddumandnew
Joined Jun 6, 2019
23
Sorry to be a pain. I've tried to get an RGB LED to swith between green & red accorging to the output of a 555 timer. The output is giving high and low as required but all I seem to have done is create a very complicated way of having a green LED lit up (never off).
This is about the only configuration I haven't tried. Before my head explodes from soldering and de-soldering can anyone see if this will or won't work? The problem Ican't get my head around is the common cathode of the RGB and how to deal with it on the NPN & PNP.
dl324
Joined Mar 30, 2015
18,467
You can eliminate the NPN transistor and its base resistor. If the timer output isn't high enough to turn off the red LED, add a diode on the emitter.
Get a solderless breadboard so you can test circuits before getting out the soldering iron.
Olddumandnew
Joined Jun 6, 2019
23
Won't I fry the 555 if I just go straight from the 555 base to the LED? (I should have added, I intend to have a 2nd load coming out there. Not very high current (20mA or so).
As for the solderless breadboard, I've got loads but spend my time tracking down loose jumpers when something doesnt work.
dl324
Joined Mar 30, 2015
18,467
You still need the current limiting resistor. If you're using a bipolar timer, it can source 200mA.
If you're using #22 wire, you need a better breadboard. If you're using thinner wire, you shouldn't go smaller than #24.
Loose wires are an opportunity to improve your troubleshooting skills.
Olddumandnew
Joined Jun 6, 2019
23
dl324, you're a star. The diode did it :) (although I sort of like the brown LED that red & green gave without it). I need to look again at it and get to understand the circuit a bit more (ie what's going on with the diode, base and emitter)
Huge thanks. Now I also have to see how well it works with the "other load".
