555 timer
38,503
That won't work well as you have the second 555 trying to brute-force pull the first 555 output low, when it is high.
You could add a resistor at the first 555 output to allow that.
Reza_liaghat
Joined Jun 17, 2016
12
Of course, I can use an mcu, but if I give up this method for now, is there another way?
For example, if 8 seconds is increased to 10 seconds, i have to compile and program mcu again.
sghioto
Joined Dec 31, 2017
8,634
For example, if 8 seconds is increased to 10 seconds, I have to compile and program mcu again.
Correct, but in my opinion it would be quicker and definitely more precise then adjusting potentiometers.
I only posted the 555 circuit to show it's possible going analog.
With the pots there is a limit to the timing before having to change component values.
With the micro, unlimited timing options.
