555 timer circuits.
Status
Not open for further replies.
Sonny120
Joined Nov 5, 2023
15
Good night.
I am having trouble creating 555 timer circuits which will give the following outputs.
What I was trying to do is create 2 50% duty cycle signals. The peak is 5 V and 0 V at the bottom. With Signal B being phase shifted by 90° from phase A. While C is the 2 signals being AND'ed. D is both signal being OR'ed.
My main problem is I'm not sure how to go about making the 2 50% duty cycle circuits for A and B. The frequency of the circuit is supposed to be 200 Hz. Is there a simple way to do this?
38,909
As noted by eetech00, waveform D is not the OR'd signal, it is the NOR'd signal.
My take on a circuit, which is as simple as I can make it (below):
The 555 is adjusted to give a 800Hz frequency for 200Hz FF outputs.
The 555 output does not need a 50% duty-cycle since both FF's are triggered on the rising clock edge, which gives an exact 50% FF output duty-cycle and 90° phase-shift, independent of the 555 duty-cycle.
The "C" AND signal is generated by the inverted FF signals connected to a NOR gate.
Note: Tie all unused CD4001 inputs to ground.
Ian0
Joined Aug 7, 2020
13,306
What's the point of Q1, D1, D2 and R2.
You could do it more simply by using the 555 to clock a 4017 and taking Q0 and Q2, with reset connected to Q4.
Sonny120
Joined Nov 5, 2023
15
Thank you guys for all the responses It was a NOR gate that I meant sorry for the mistake These circuits seem very reasonable.
Sonny120
Joined Nov 5, 2023
15
By this you mean create the 200Hz clock then use a 4017? Also by Q0 and Q2 do you mean the first clock in that quarter?
Ian0
Joined Aug 7, 2020
13,306
Still don't see how that gives the 90 degree shift with a CD4017 since only one output is high at a time(?).
Screenshot from 2023-11-19 15-07-41.pngbut I can't make it work in SPICE with a diode OR-gate.
Something to do with setting the output current of the logic device. ...
Status
