555 PWM
ericgibbs
Joined Jan 29, 2010
21,609
hi Matt,
Bread boards do have limitations with some circuits.
The inter pin row capacitance and insertion resistance can cause problems.
I guess you had adequate decoupling of the BB power rails.?
Have you had the chance to try the buffer mod.?
E
MATT838383
Joined Jul 31, 2019
144
eric
Have you had the chance to try the buffer mod? sorry no
i guess you had adequate decoupling of the BB power rails.
here is my model!
ericgibbs
Joined Jan 29, 2010
21,609
hi,
I bought a batch of Arduino Nano Shields that came with BB's similar to your image, very disappointment with their performance.
What's your next planned step with the project.?
E
MATT838383
Joined Jul 31, 2019
144
Eric
next step is trying to synchronize the pwm with the ic and connect it on the transformer
thats why i need a fixed frequency (hope we will find a solution)!
MATT838383
Joined Jul 31, 2019
144
Eric i have turned around the net for a circuit application but it seems complicated for me! can you give me a schematic to test it?
thank you!
ericgibbs
Joined Jan 29, 2010
21,609
hi,
It was not for the actual PWM section, but the 'tri' generator, which appears to be the section thats got the frequency shift from 0% to 100%
E
ericgibbs
Joined Jan 29, 2010
21,609
Hi Matt,
Can you confirm the supply voltage is it 5Vor 12V, also could you measure the actual voltage on the wiper of the Mod pot at the PWM limits.
E
ericgibbs
Joined Jan 29, 2010
21,609
hi matt,
Have been running tests using the resistor divider and the pot, nothing shows any change in frequency.
That is 4k7 > 47kpot > 4k7.
When the pot is at 0% rotation what is the Mod voltage, also what is the Mod voltage when the pot is at 100%.
E
Update:
LTSpice two examples of the circuit, pot 0% and pot 100%.
The frequencies are identical. at 227Hz.
Added:
Showing the Mod voltages at the lower and upper limits of the 'tri waveform.
