- Joined Jan 23, 2018
- 28,311
Indeed! The present circuit keeps the transistor on far to long, amongst other problems. But there is the positive pulse as desired, but a much greater negative pulse. You could use a bridge rectifier and capture all of that across a capacitor, but that is probably a lot more than you want. I suggest using a switching regulator IC instead of a 555, since there are ones made for exactly this sort of application, although not that high a secondary voltage. Texas Instruments has a whole lot of support software and a good number of examples on their website.The original circuit is bad, both with a diode and without. In both cases, everything will end with the death of the transistor!
Display the power of the transistor (use the ALT key).
But if you want to keep on with the 555 the first thing to do is make the output pulse much narrower.At some point the energy delivered will match the energy your application needs. that should help a bit.
