555 Help!
Martyn
Joined Oct 27, 2010
20
Hi Guys
Can anyone help me with my question?
Im trying to make a circuit with a 555 timer that will allow me to press a momentary push to make button and then latch the output (which i have managed to do).
However I also need to the circuit to be able to switch off an output using a relay or similar when either a external -ve or +ve is detected using the same on/off switch.
I have attached a basic circuit below as to what i i have done so far.
Can any of you guys help me?
Thanks
Martyn
Joined Oct 27, 2010
20
Basically what i want is to be able to turn somthing off with the switch using a relay or somthing like that.
Im thinking that when a 12v signal is detected it will illuminate the LED but i can override the signal with my button thus firing the relay and removing power to the LED.
Martyn
Joined Oct 27, 2010
20
Hi Bill
Thanks for the responce.
Are you saying that the circuit you posted is what i need? as i dont understand how it will let me overide when a signal is detected.
Thanks
Wendy
Joined Mar 24, 2008
23,869
The circuit I showed is a simple flip flop, but it can also be reset with the reset input on pin 4. I am not sure I understand your requirements, but I think this fills them. Reset on the 555 overrides all other inputs.
