555 astable starting low?
SgtWookie
Joined Jul 17, 2007
22,230
Connect the timing cap from Vcc to pins 2 & 6 rather than from 2 & 6 to ground.
On power-up, pins 2 & 6 will be pulled to Vcc instead of ground, which will start the output off low.
This trick won't work if you're using the RESET pin to restart the timer.
If you wish to eliminate the extra time delay on start-up, then use 2/3 of the capacitance from Vcc to 2 & 6, and then 1/3 from 2 & 6 to ground.
Wendy
Joined Mar 24, 2008
23,862
Most of the astable functions of the 555 use the Discharge pin 7, so that solution has problems of its own. You could use a transistor to invert the discharge, or use a transistor to invert the signal.
SgtWookie
Joined Jul 17, 2007
22,230
Actually, nothing needs to be inverted. Have a look at the attached pair of schematics and simulations.
There may be a small "glitch" on the output until Vcc comes up to within the operating Vcc range of the 555. Vcc is taking 20uS to come up to 12v, and for about the 1st 6uS the output is following Vcc.
Whether this glitch would occur with real-world parts is beyond me at the moment; don't have a 555 and a scope to test it with.
Philexium Digital Design 12
