Hi, I took apart an old LG monitor and it has a ChungHwa CLAA150XG, the panel connects to the board by two 50 pin ribbon cables and the only LVDS to TTL converters I can find are for one 50 pin cable only, will it work with only one cable?
I've seen a CLAA150XG-08 on ebay that has only one of the connectors, is it safe to assume it will work with only one?
Is the 50 pin connector the same on all 50 pin TTL screens?
