4 Pin 5050 LED Strips Flash White in Fade 3 Cycle, is there a better controller that would fix this?
Icewing726
Joined Aug 10, 2018
Hi, I purchased some pretty cheap LED Strip lights to go around the dropped crown molding in my office. I used power injectors for each strip and everything seems to work great EXCEPT when it transitions between red and orange. Every time it hits that point theres a flash of white like a click... its almost like when people try to make a song loop but don't line the notes up perfectly. Just a real quick blip and back to the normal fade.
Like I said, I think that the controller is at fault. However, I've also wondered if maybe I put too much power in the loop (I didn't use the 3 amp power supplies it came with, instead I purchased 6 amp versions since I originally planned on daisy chaining without the injectors). Thoughts?
Icewing726
Joined Aug 10, 2018
Soooooooo are you saying if I spend 50 dollars per strip it won't have that issue, or is that still poor quality? I mean it hits all the colors and does the flash only at the end of a 3 color fade cycle, every time. Any ideas on why so I don't waste a day and a lot of money only to repeat the issue?
Papabravo
Joined Feb 24, 2006
22,116
No. This is a situation where you have to be able to see it work before you buy it, or be able to return it if it doesn't work the way you want it to work. There are a number of ways to accomplish this, and you may have to spend more to find what you want.
Reloadron
Joined Jan 15, 2015
7,980
The controllers for these things normally offer several routines to choose from on what the LED string will do. Each routine uses a different code scheme. My guess would be a bug in the code for the scheme you are running. A flash of white would indicate all the colors of R, G, and B at their maximum values. The fact that the error repeats on a regular basis would indicate a bug in the code running on the controller.
Ron
Papabravo
Joined Feb 24, 2006
22,116
Ron
As we often find in this business, it might not be a bug, but a feature!
Reloadron
Joined Jan 15, 2015
7,980
Can't rule that out.
My friend dressed out his motorcycle with RGB LED strips including a controller offering several routines. While real nice and catches some lookers at bike nights I have no plans to light up my bike. However out of curiosity I dug out an Arduino Uno and a few MOSFETs and played around with a RGB strip. While I can't remember what I did but I had a similar effect in my code. They would do a transition and there was a blink of white. I eventually got rid of the bug which was in my code and got nice transitions. Those little projects kept me amused for a few weeks. :)
Ron
ronsimpson General Electronics Chat 5
Similar threads
fake fireplace led strips
