Yes, the cathodes of the two diodes should have a wire connecting them, and then to the 47 Ohm resistor.On Chip 4017 should 3 and 4 be connected like 5 and 10?
The programmer I found really good is PicKit2 it was half the price of the orginal programmer I got, and it programmed the chips quicker. It also works with Microchips software MPLAB... you can compile and program all from the same software, and also debug it while its running.Is this the programmer that you was talking about earlier? http://home.maine.rr.com/randylinscott/aug20.htm
Also does anyone have any pictures of one built they could post?
by Aaron Carman
by Duane Benson
by Duane Benson
by Jake Hertz
