4-20 Ma Current loop receiver working with charger
ronbo76
Joined Apr 2, 2018
20
Hi Everyone
I was going through some old Forum question and using it in my new project
As I have wired in parallel to keep the same voltage and increase the capacity of the battery
i am trying to figure out a way to charge these batteries as i will use them as a pack inside of a sealed enclosure.
anyone have any ideas for a simple charger for these in this wiring configuration. its around 3.7V - 4.2V and ~3600mAh.
i want to be able to use the device its powering and charge at the same time if possible.
Just Similar to cell phone. you can charge and talk at the same time. how should overcharging will not take place and we will be able to use the simple method
Is there any possibility of using 4-20MA Current loop Receiver which help us not to overcharge the device from either analog or DC voltage
