We need to setup a 3 switch wherein if more than 2 switch are open, the LED will light. Materials should only be 2 transistor NPN and 2 PNP transistors, LED , resistors and wires. If switch is off it will generate negative volt, else, it will give +5 volts ( There is also a separate - and +5 volts source aside from the switches) (Switches are from the Digital trainer). It doesn't matter where LED will glow very bright, as long as there is a light on led, it counts as on.
Is it possible to make a circuits with only 2 NPN and 2 PNP transistors?
