3 phase transformer neutral
PAULSINCLAIR
Joined May 3, 2017
12
I have a 3 phase transformer (see below). I want to step down from UK 3 phase (415V) to US 3 phase (230v). I was thinking, connect the 3 phases to H1/H2/H3 and don't connect the UK neutral, then X1/X2/X3 are the 3 US phases with X0 being used as the neutral which i will connect to ground.
Phases, 415 on H1,H2,H3 neutral is not connected.
115/200 is on X4,X5,X6 with N on X0
Adjust the primary taps to trim the voltage, a higher tap voltage setting will result in a lower outtput....
Al Its all on the label...
If you do not know what you are doing get physical help, this stuff can kill you and burn your family/employees.
My comments in no way constitute a design.
A qualifuied installer will need to design and test and certify the protection required for the transformer and anything connected to it.
Ignoring this warning will probably kill someone... DONT .
I am not kidding or blustering at these energy levels you dont walk away, simply dropping an uninsulated tool could blind you or worse.
Al
MaxHeadRoom
Joined Jul 18, 2013
30,759
The primary indicates Delta connection anyway. So no neutral involved on the primary.
The connection is as the plate indicates surely?
Max.
PAULSINCLAIR
Joined May 3, 2017
12
chill out man
Al
