3.6V NiCad battery charger with auto cut off
sanjubluerock3
Joined Mar 22, 2011
Hello, I made this charger circuit for 3.6V NiCad Battery with auto cut off just wanted to check if this works or3.7V NiCad battery charger with auto cut off.png any modification required?
Dodgydave
Joined Jun 22, 2012
11,395
Looks ok, but as the Nicad should be charging at a Constant Current rate, your circuit will drop current as it charges upto 4.3V, then the op amp will shut off and may keep pulsing on/off as there is no Hysteresis levels . I would put a 470K resistor on pins 3,5 to prevent pulsing.
ian field
Joined Oct 27, 2012
6,536
Hello, I made this charger circuit for 3.6V NiCad Battery with auto cut off just wanted to check if this works orView attachment 160505 any modification required?
Worth having commercial chargers sense the very small drop in terminal voltage when it reaches full charge. (much smaller drop with Ni-Mh).
Temperature sensing has worked for me.
Cheapo commercial chargers just use a timer - the end result is pretty much dumb luck.
38,912
Your circuit will not correctly charge your battery.
You cannot reliably determine the charge status of a NiCd battery by its end voltage.
That's why good chargers sense the small change in end voltage to terminate the charge, often along with temperature sensing, to properly charge NiCd batteries, as Ian noted.
sanjubluerock3
Joined Mar 22, 2011
Thanks a lot! I will try to build this circuit next week and post the results.
