- Joined Jan 23, 2018
- 28,013
OK, so now we know that the meter is reading a signal from a variable speed drive system. And with the signal being zero to ten , probably correlating zero to whatever the max output of the drive is, it becomes clear that it would be very handy to have the scale calibrated in units that corresponding to what the output means. That is simple to do with a good process meter. I have done it and it is all done from the front panel of the meter, following instructions in it's manual.
So the TS needs to go to the Red Lion website and select process meters. And if they don't still have them Automation Direct should have them. Possibly cheaper, as well.
But there is a question as to why the drive current drops. For the screw drive in an injection molding machine, that would either be a blockage in the granular feed supply line or else the heaters have got the temperature excessively high. The motor drive current is a quite good indicator of the motor load, which depends on the viscosity and density of the plastic charge load.
