2nd Order passive Low Pass Filter
Alexandru Chiser
Joined Feb 16, 2017
44
The 2nd filter acts as a LOAD for the first filter. So, this load has an impedance equal to R2 + 1/jwC. Basically, at the first filters output we connect an impedance equal to R2 + 1/jwc. Right?
AnalogKid
Joined Aug 1, 2013
12,214
Right.
AND, this is why if you do things this way the 2nd stage impedance should be at least 10x the first stage impedance. The higher the impedance of the 2nd stage, the less it loads and alters the corner frequency of the first stage. 10x is a standard engineering *approximation* for the beginning of the range where things do not matter. When one impedance is in parallel with another, the loading effect is officially "relatively small" at a ratio of 10x. Obviously, 50x or 100x would be even less loading. And, how much loading is too much depends on the actual circuit and its required performance.
ak
Alexandru Chiser
Joined Feb 16, 2017
44
I`ve done some tests with the following configurations:
1) 2 1st order filters cascaded
Calculus: 33Hz - Simulation: 14Hz - Reality: 14Hz
2) 2 1st order filters isolated by op-amp
Calculus: 33Hz - simulation: 22Hz - Reality: 23Hz
So the 2nd version is better because is closer to the ideal case
Bordodynov: i simulated the same circuits, but with different values. I obtained the same results (ofc, different frequency, but the characteristics were the same). :cool:
38,611
You calculus is off.
Remember that the standard 1/2piRC calculation is the -3db point of one RC filter.
For two filters in series that gives the -6dB point, with the -3dB point at about 22Hz as the simulation and measurements show.
So to get the -3dB point of the combined filter, you must calculate the -1.5dB point of each filter.
Alexandru Chiser
Joined Feb 16, 2017
44
And how do i do that? What`s the formula?
PS: in the simulation the -6dB point is exactly at 33Hz...
PS2: so.. for a 2nd order filter, i should look for the -6dB or the -3dB to find the cut-off frequency?
PS3: in the simulation the phase of the first filter at -3dB is -45*, and for both filters at -6dB is -90*...
Can you please explain me?
38,611
The -3dB point for the combined filter is where each filter has a rolloff of -1.5dB or 0.8414.
The transfer function of an RC low-pass filter is
so you solve the equation for the frequency where Vout/Vin = 0.8444.
I'll leave that algebraic manipulation as a exercise for the reader. ;)
Normally the cutoff frequency is defined as the -3dB point.
What's to explain?
The phase-shift of a single-pole RC filer is 45° at the -3dB point.
The phase-shifts of the two filters in series add together at any frequency.
Alexandru Chiser
Joined Feb 16, 2017
44
So... i`ve done the algebra and i came up to this:
0.841395 = 1 / sqrt(1 + w^2R^2C^2)
0.841395^2 = 1^2 / 1 + w^2R^2C^2
1 + w^2R^2C^2 = 1 / 0.841395^2
=> w^2R^2C^2 = 0.412 => w = sqrt(0.412 / R^2C^2) => w = 0.64 / 10K * 470nf = 136.63
w = 2piF => F = 21.74HZ.
This is indeed the frequency at -1.5dB FOR ONE FILTER, as the simulation shows
But for 2 filters, the transfer function is:
1 / (1+jwRC) * 1 / (1+jwRC) (you multiply the transfer functions of the both filters), this being equal to: 1 / (1 +2jwRC - w^2R^2C^2) and... i`m stuck here... I don`t know if it`s okay and i should calculate for -3dB (Vout/Vin = 0.707). I`m stuck at calculating the absolute value of the denominator...
Alexandru Chiser
Joined Feb 16, 2017
44
Regarding the time constant,
A 1st order filter has T = RC. In my case, both of the filters have the same time constant. But what`s the time constant of the whole system? I`m pretty sure it`s a little bit bigger than the time constant of 1 filter, maybe 2 times?
Theory says: time constant is where the Capacitor charges at 63%. So i simulated my circuit, where i apply a 1V amplitude PWM signal, with 98% duty cycle. This means that the voltage at the output of the filter is 0.98V. 63% means = 0.6174. This is the simulation:
RED line - 1st order filter (the first filter, before the op-amp) - it has a time constant of aprox 4.67ms
GREEN line - the output of the whole circuit - it has a time constant of aprox 10.02ms...
38,611
From Wikipedia:
In physics and engineering, the time constant, usually denoted by the Greek letter τ (tau), is the parameter characterizing the response to a step input of a first-order, linear time-invariant (LTI) system.
Thus the time-constant only refers to the response of a first-order circuit with one RC (or RL).
It does not apply to your circuit with two cascaded RC filters.
Alexandru Chiser
Joined Feb 16, 2017
44
[QUOTE="crutschow, post: 1250133, member: 19451"
It does not apply to your circuit with two cascaded RC filters.[/QUOTE]
But, as you can see... the voltage stabilizes at different times (depending where i measure, at the output of the first, or the second filter). I know that the ripple is lower, but why does it take longer to stabilize at the output of the whole system?
