2N4401 Vs. 2N3904
DaniKowa
Joined Sep 23, 2020
218
I was taking a look at the datasheets of the 2N4401 and 2N3904. All two TO-92 and 40V containers from Vceo though:
- the 3904 can dissipate up to 625mW and has an Ic of 200mA
- the 4401 can dissipate up to 250mW and has an Ic of 600mA
obviously they are maximum values but they are not few 250mW with an Ic of 600mA. Why would that mean that with only 250mW of dissipation it would only be possible with a maximum of 6.2mA? But then why so much difference on the dissipation equal to the container? The question arises from the need to understand which of the two is more suitable for a small class A in push pull with complementary PNPs in parallel.
The second question is related to the connection of the load which in this case is 8 Ohm but it is not important (I think) at the end of the question.
Normally the load is connected like screen 2 but can it be connected like screen 3?
Thank you!
DickCappels
Joined Aug 21, 2008
10,661
In my book the two are interchangeable. The data sheet pages you posted seem to suggest the same. I have been using them interchangeably for over 30 years, into the tens of MHz for amplifiers and over 100 MHz for oscillators.
If you use configuration B (as in your circuit above) it looks like the signals going into one input needs to be inverted with respect to the signal going into the other input. But why do that -I don't see any benefit to it, but I do recognize and opportunity to have DC voltage across the load.
Ian0
Joined Aug 7, 2020
13,281
When I see an 8Ω load resistance I immediately assume Audio, and audio requires an AC output signal.
Circuit #2 can produce an AC output signal, and Circuit #3 can't.
DaniKowa
Joined Sep 23, 2020
218
Do you know if there is a database with all the pairs of pnp and npn transistors that can be used as complementary?
Ian0
Joined Aug 7, 2020
13,281
Yes it's true but why but how come one can handle 200mA and the other 600mA?
If you compare the two data sheets from the same manufacturer, it shows the 2N4403 with larger capacitances, suggesting it has a larger chip.
Once upon a time, manufacturers included a dimensioned photo of the chip in the datasheet.
DaniKowa
Joined Sep 23, 2020
218
Sorry if it is not specified. I forgot to mention that the signal is AC. So correct .
DaniKowa
Joined Sep 23, 2020
218
Here's why! . Then the 440x pair might be more suitable than the 390x for a current buffer stage as a power amp if I'm not mistaken. While the 300x as a vbe amplifier (driver stage?)
WBahn
Joined Mar 31, 2012
33,211
They are different transistors. One was designed for use at higher collector currents than the other. If you look at many of the performance parameters, you see that the 2n3904 is better optimized for operation at a lower current than the 2n4401. For lots of applications, the difference isn't enough to draw attention and so they are effectively interchangeable for those applications.
Ian0
Joined Aug 7, 2020
13,281
The 2N4403 is famous for being a really low noise amplifier for very low impedance sources such as moving coil cartridges, capable of sub 1nV/√Hz
BobTPH
Joined Jun 5, 2013
11,656
The power dissipation limit has only to do with the package and how much heat it can dissipate without raising the temperature of the silicon above its max. This has nothing to do with the max current the transistor can handle.
Audioguru again
Joined Oct 21, 2019
6,826
Did you read the specs and see the curves in the datasheets?
1) The 2N3904/2N3906 have a max allowed current of 200mA but their specs and curves show poor performance above 50mA.
2) The 2N4401/2N4403 have a max allowed current of 600mA but their specs and curves show poor performance above 200mA.
Instead of many weak little transistors, why not use two power transistors with little heatsinks? Also their emitter resistors can be 0.22 ohms for much less voltage wasted.
The transistors have a max allowed voltage of 40V so make your circuit safe with 30V. Your paralleled transistors have 20 ohms/5= 4 ohms of emitter resistors in series with the 8 ohms speaker then the max peak current in each group of 5 transistors is 14V/(8ohms+4ohms)= 1.17A or 233mA for each transistor.
Your amplifier with a 30VDC supply might produce 8.2W RMS total in the 8 ohms speaker in series with the 4 ohms emitter resistors or 5.5W RMS in the speaker plus 2.7W in the emitter resistors. The transistors heat with about 800mW each. Then they will overheat and be destroyed.
Using TIP31/TIP32 power transistors with a 30V supply, the amplifier output power will be about 12W RMS and each output transistor needs a little 8W heatsink.
DickCappels
Joined Aug 21, 2008
10,661
Unfortunately it all depends on whose datasheet you are looking at. Checking the Fairchild 2N3904 and 2N4401 data sheets, they both list 800 ma as the absolute maximum current rating.
WBahn
Joined Mar 31, 2012
33,211
I have run across a few charts that list complementary pairs, including one only a couple weeks ago. I'm sure it's far from all-inclusive.
I tried doing a search just now and didn't find anything quickly -- but they are out there.
