24v dc to 24v ac .. #2
Spit
Joined Mar 14, 2022
2
Hi there,
Good question
We have 24v dc 400w with batteries from a solar system and need to ran my water system on 24v ac 800mA
Is there a circuit that can help me as I don’t want to put a inverter near my fence.
nearest power point is 75m from the water point
Thanks
Sorry forgot 50hz
22,082
What you want sounds like an inverter, but you don't want to use one of those. There is no other circuit that I know of that will do what you want. Do you have any shred of a reason to believe that such a circuit exists? If so, would you kindly trot it out?
Ian0
Joined Aug 7, 2020
13,132
It’s only 20W - an audio amplifier would do it.
But my suggestion would be to buy a DC version of whatever undisclosed piece of equipment needs 24V AC.
Ian0
Joined Aug 7, 2020
13,132
It looks like you are controlling water valves so 50 or 60hz does not matter.
There are small solar 24V to 120 or 220 volt inverters. Next use a 120V to 24V transformer.
That product claims to be 100% efficient. What’s it made out of?
If that is true, why does it need a fan?
An inverter (except the 100% efficient types) has a no load current of about 1% of total load. That would be at least 30W.
bassbindevil
Joined Jan 23, 2014
922
Sprinkler system valves run on 24 VAC, and according to this there are problems running them from DC. So, 50 Hz sine wave (from an 8038 or 2206 function generator board) driving a class-D audio amp could work, or maybe just a 50 Hz h-bridge driving them with a square wave would be OK. Or, the very obvious solution: 50 Hz inverter and a transformer.
Ian0
Joined Aug 7, 2020
13,132
Seems to me that using a constant current solenoid driver off DC would be the simplest solution. A buck-derived constant current LED driver IC would work well as the solenoid acts as the inductor in the circuit.
Even better would be to use an LED driver IC with an analogue dimming input, and use that to pulse the solenoid to full current at startup then back it off to 300mA.
Before I spend any time drawing it up, I note that the TS has yet to confirm whether our assumptions are correct that it is solenoids that require AC.
