schmitt trigger
- Joined Jul 12, 2010
- 2,298
Exactly.Let's have a talk among ourselves.
The single-post-ever thread starter was last seen here over 6 months ago.
400Hz is not that hard to achieve. Can programmable MCUs help?A 400hZ 120 volt inverter could be a useful device to have. I wonder about revising one of those small package 60 Hz 120 volt inverters to deliver.
Unfortunately FAIR RADIO seems to have gone out of business.
Certainly there are simple ways to generate a frequency accurately. It is always THE POWER LEVEL that is the challenge, when other than the mains frequency is required.400Hz is not that hard to achieve. Can programmable MCUs help?
The 400 Hz is easy enough with just about any MCU. The difficulty arises with getting a 400 Hz sine wave at the desired power level of 500 watts. That takes a little more doing. Guessing a function generator chip like the XR2206 for the sine wave and maybe a IGBT to amplify it. Using a uC you end up starting with a square wave.400Hz is not that hard to achieve. Can programmable MCUs help?
| Thread starter | Similar threads | Forum | Replies | Date |
Unavailable 230VAC to 5V 1A Linear PSU? | Power Electronics | 15 | |
| A | Resistive vs capacitive dropper for 230V AC button sensing | General Electronics Chat | 54 | |
Rewinding small 230V synchronous motor for lower voltage e.g.12V/5V | Power Electronics | 9 |
