200 Vdc power supply
Hypatia's Protege
Joined Mar 1, 2015
3,228
the input is 50 to 2000 vdc and the out put is 200 vdc 300 watt
is there any suggestion how we make this circuit
Standard SMPS (cip 'bi-directional' DC-to-DC conversion) techniques but with special attention to accommodation of high input EMFs...
Be advised, however, that the width of the stated input range entails formidable design challenges...
Best regards
HP
R!f@@
Joined Apr 2, 2009
10,010
Where can you get 2000VDC.
If you cannot design a circuit that uses 2000VDC I suggest that you stay away from making one that any other had designed.
You do not understand the risks involved if you were to make a tiny mistake.
Roderick Young
Joined Feb 22, 2015
408
By any chance, is that a typo, and do you mean 50-200 VDC input? I have a bit of experience with design of switching supplies from my previous job, but still wouldn't dare advise on a design over 400 volts input.
Kermit2
Joined Feb 5, 2010
4,159
research high voltage IGBT and BiMOSFETS. Infineon and Mitsubishi Electric specifically.
a switching bridge and step down transformer would be the way to go.
2000 ? volts. wow! what is the source of this wide ranging input? Solar?
