Completed Project 200°C SMT Hot Plate
Wendy
Joined Mar 24, 2008
23,805
Something I learned as a machine maintenance tech in a clean room is preheating a part to 200°C Makes it much easier to solder. I designed and made several for the production line for this purpose. So designing this one just more of the same. My stroke left me unemployable so cost was a major factor with this design. Wood is cheap and surprisingly temperature resistant and insulative. 200°C will char it but doesn’t seriously damage it.
First step is to get the sheet metal. I got a .01” x 12” x 12” sheet metal and used the following pattern to cut 6 metal spacers shown in the .png file (print this pattern using M$ Paint and the individual sheet is to scale). You will also need a piece of ¼ thick aluminum for the top of the hot plate. I countersunk and tapped the holes for a #6/32 screw. This is important, as it will simplify construction later. Also drill a 0.1” hole in the side of the back of the top plate as deep as you can to immerse the thermocouple into. I used high temperature RTV to make it stay in place. So after cutting and drilling the spacers to spec I started assembly. The 1.0” x 1.0” notches give the square bumps on the heater spaces to go when stacking the heater elements (Qty 4). You will also need a separate unnotched bottom plate. Assemble as shown.
After you are done stacking the metal plates (spacers) and heater elements (Quantity 4 of each) unite the hot assembly the with a #6/32 nut, this will form a space between the wooden base and the heater assembly (which will char the wood less later).
You may want to add a washer to try making the heater assembly sit flat on the wooden base (even with the notched spacers the heater elements bulged a bit.
The wooden base will need 6 holes for my #6 wood screws. Label each hole with the terminal number,
Do yourself a favor and crimp the lugs on before starting the stacking phase and if you are real adventurous cut the lead lengths too (I’m chicken and used the entire wire length). I labeled each lug with the resistor number matching the terminals shown on the schematic. I also labeled the terminal holes on the base block (hidden hidden below the lugs) for easy reference. Take the time to add spacers as needed to level the total hot plate assembly and match the heights of the wrap around wooden frame. Mostly this is for appearance.
Schematic
Then wire the hot plate as shown.
After I was done I used a hobby stick to flatten the wires
A quick note about the power supply, you can use a 24VAC transformer and a commercial proportional power controller in lieu of a variable power supply. Since I do have a variable DC power supply that is what I used.
It took 22 minutes for this unit to hit 190°C, I adjusted it to 18.75 VDC (78%power) where it stabilized to approximately 200°C.
When I turned it off in 1hour 10 minutes the hot plate cooled to 60 °C. In 3hours it was 28°C. Now you know why the timer was in the picture.
Wendy
Joined Mar 24, 2008
23,805
BOM
Qty Description
4 .....0.1” Spacer Plates (download "SMT Hot Plate v3.png)
1 .....¼” Surface Plate I bought a 4" x 4½" x ¼" aluminum sheet (I bought mine from Metal Marketplace.
1.....0.1” Bottom Plate
4.....Heater Mats
2 .....#6/32 x 2” counter sunk flat phillips head screws
4 .....#6/32 nuts
2 .....#6 small washers
2 .....#6 split ring lock washers
1.....¾” x 4” x 4.6” Wooden Base (I used plywood)
4.....#6 x ¾” pan head wood screws
4.....1” square ¼” high rubber feet (highly recommended!)
4.....25W 12V Silicon pad heaters18[wh].....[/white]#6 crimp on lug ring terminals
.......Wire to carry up to 4 amps 20 Ga or better.
1.....24V 4A Power Supply (variable preferred)
1.....Type K thermocouple and meter
Wendy
Joined Mar 24, 2008
23,805
Ewww, that's just wrong.
Did you click the link in in the BOM? Store bought parts are hyperlinked. It's kinda my thing.
ErnieM
Joined Apr 24, 2011
8,415
Nah, I copied "Silicon pad heater" from the BOM and searched on that to get general info.
MY EYES!!! MY EYES!!!
metermannd
Joined Oct 25, 2020
472
Well, that's worse than when I was doing a search for an obscure Westinghouse electronic assembly on the E place and finding a "sponsored link" for maternity bras right in the middle of the search results!
ErnieM
Joined Apr 24, 2011
8,415
A few years back while working for a place with a very strict pr0n policy I searched for some compounds by Emerson & Cuming.
I clicked the first hit without reading... OOPS
