2 current sources. circuit analysis
WBahn
Joined Mar 31, 2012
33,321
What is your best attempt at answering the question (including the why part)?
That will help us figure out where your thinking is getting stalled and try to help you address those specific points.
jericoperlas
Joined Oct 11, 2017
7
I = 5A
V = 100V
P = 500W
this is what i originally thought. and then i put it into a circuit simulator and its saying the 4 A current source wouldn't output. that's whats throwing me off. hence the color grey in the photo.
WBahn
Joined Mar 31, 2012
33,321
I = 5A
V = 100V
P = 500W
What simulator are you using?
It appears to be one of these online easy-to-use simulators. These often have problems.
I would recommend downloading and learning how to use LTSpice. It's free and it's a real simulator intended for real work. While you can get up and going very quickly with it, there IS a learning curve that has to be dealt with as you go. The good news is that there's a lot of folks here that are very proficient with it (not to mention user forums dedicated to it).
jericoperlas
Joined Oct 11, 2017
7
So am I right?
Generally two current sources connected in parallel can provide current flow into load equal to the sum of these two current sources.
In series current sources are not defined, and there is no guarantee what you will have.
In your case following calculation looks right:
I = 5A
V = 100V
P = 500W
MrAl
Joined Jun 17, 2014
13,859
Yeah that's weird about the simulator because everybody who analyzes circuits knows that currents add like that.
It must have gotten confused or the designers took too many short cuts to a solution.
Now voltage sources are a different story, two of them in parallel are not allowed unless maybe they are the exact same voltage.
You connected the resistor terminals to the 1A source directly. That's why the "connections" for the 4A source are red circles. You need to connect the resistor terminals to the 4A source first, and then to the 1A source.
WBahn
Joined Mar 31, 2012
33,321
Even then it would get many simulators fits because the solution is indeterminate -- pick any current you want in one source and you can find a current in the other source that is a solution.
And the same indeterminancy issue exists with two identical current sources in series -- the voltage across one can be anything as long as the voltage across the other compensates.
If the simulator assumes at least some internal resistance, then the solution can converse. but the same is true for current sources in series.
