Into HSMM-MESH big time and wanted a way to see where my antennas or other devices really were spectrum wise.
Therefore, I am building my own poor man's spectrum analyzer.
I actually have one running now but I recognize that it needs to be better.
Not being very smart on these things and not an engineer but having been exposed to such things enough to be encouraged I have put together a 2.4 gig VCO swept by a 555 generated constant current charged saw tooth.
Running between 1/3 and 2/3 VCC, which is not what I wanted, I need 2 volts to 15 volts P/P. Or 2 to 17 volts depending on which VCO you get.
Since the VCC spec on the 555 is 18 volts max I am taking a risk with running it at 24 volts VCC in order to get the 2/3 VCC top rail of 16 volts so I cringe every time I apply power.
I don't like taking the sweep voltage from the charging CAP because it has to feed both the VCO and the horizontal input of the scope.
So I need some advice on how best to amplify, split, match the sawtooth.
My first impression is to add an OP AMP but that is where the problem is.
Thanks, Joe
Thanks, Joe
