1Amp tuned resonant LC circuit
BastelBaus2
Joined Aug 2, 2024
11
Dear community,
I have a 1mH coil and want to drive it in resonance digitally controllable between 20kHz and 30kHz with up to 1Amp P2P. Any Idea's how to achieve it? My idea's so far:
- half or full bridge mosfet drive with PWM from DSP/uC and fixed C (i.e. 60nF for 20kHz) works well
- varactors / variable would be nice, but I don't have experience with them
--> they seam not to be available for this capacitance range (rather at pF)
--> I would need something like >10V and in the range of >100mA which seams also too much
Any ideas / hints how I could achieve this ?
BR, BastelBaus
Would small frequency steps be OK? I do not have an easy answer as to varying capacitance by nF otherwise. I believe you are correct that varactor diodes work in the pF range, and probably only with low signal levels.
I am proposing binary steps switching added capacitors in parallel.
BastelBaus2
Joined Aug 2, 2024
11
Boundary_A_La_Mode you might be right, some more details;
I want to rebuild this 3D coil sender: https://www.amfitrack.com/ (or link)
- 3 coils not 1 :)
- currents ~0.5A, frequency 20..30Khz video@1m11s
- in 32 steps link
video@51s:
Or probably the same IC: video@2m32s
There are three lines with the same IC (2*7 pins + 2*2 pins) in the first video followed by several different caps and the 3D coil afterwards (and one small 6pin IC device, might be a half bridge?) . What kind of IC is this 18pin device? Does anyone know it ?
BR,
BastelBaus
28,345
You want to drive a coil to resonance?? Digitally?? All we are given is an inductance value of one millihenry.
What resonant frequency have you chosen??
A plain inductance seldom resonates. A capacitance is required to achieve resonance.
BastelBaus2
Joined Aug 2, 2024
11
Dear MrBill2,
please see my first post, 20 to 30kHz variable, with this 1mH between 60 to 160nF series capacitance to achieve the resonance.
So the my question how to vary the capacity in this range to let about 500mA flow trough he coil and variable capacitance leading to a voltage at the cap of about +/-50V.
BR, BastelBaus
William Ketel
28
OK, there is an exact formula for calculation of the resonant frequency given the inductance and capacitance values. So solve the equation for the capacitance. then use the stated inductance and frequency. That will give you a capacitance value that will be close. Then you can use a signal generator to determine the actual resonant frequency, and if more capacitance is required use an adjustable mica compression capacitor to set the exact frequency.
BastelBaus2
Joined Aug 2, 2024
11
Thanks William, then using a stepper motor with a driver would make it electrical controllable :) scnr …. Varactors are the parts normally used which have a variable capacitance depending on the dc voltage applied. But they do not exist in the 50nF range I need. So the other option might be using analog muxes to switch a capacitance bank as Boundary proposed …
BR
BastelBaus
William Ketel
28
Normally when a resonant circuit is used the inductance is selected to allow a convenient capacitance value to achieve resonance. Starting with a fixed inductance may lead to requiring some rather inconvenient capacitance values.
I could see where it might be easier to tune an inductor than a large value capacitor. Older forum participants have probably seen variable capacitors (in AM broadcast radios for example) but I think those are mostly in the picofarads. I have not investigated but in theory I would think that a ferrite or other magnetic core could be moved to vary an inductor in the uH range.
Bordodynov
Joined May 20, 2015
3,431
I used the Qspice simulator. There are special materials for rebuilding resonant circuits at high frequencies, but regular ferrites will do, but with a smaller effect.
