19" Rack Fan Project
KKRS_
Joined Oct 26, 2023
24
Hi guys,
do you know of any companies that make custom 1U or 2U 19" inch racks where you can do machining at low cost? Or 19" inch kits where cooling fans can be installed?
bassbindevil
Joined Jan 23, 2014
924
Hammond sells blank rack panels, if that's what you need. Middle Atlantic is another source and might be cheaper.
If you need to cut holes in panels to fit fans, a saber saw with a metal-cutting blade is good. Mark the circle with a scriber; the more precise the line, the neater you'll be able to make the hole.
