16 Volt DC conversion to 12 Volt AC
30,675
If it is a linear supply, you could have ~12vac on the secondary, if a simple transformer supply.
What type is the present supply?
30,675
Is it a transformer you can add a small overwind to produce the 12vac with the existing 6v ?, usually approximately 12-16 turns.
