12v power supply quick off
s200bym
Joined Aug 9, 2017
82
Hi guys,
I have a 240v ac to 12v 8A dc isolated power supply.
When I switch it off from the mains it’s has a slow shut off of around 3 seconds.
One of the spur circuits it is powering is a speaker protection board. Is there any way I can get this spur to shut off instantly?
Maybe some diodes and resistors in-line.
Kind Regards,
Mike.
gerty
Joined Aug 30, 2007
1,305
What you are seeing is probably the capacitors discharging. if you put a small load across the 12 volt side, such as a small bulb, I think you'll see it goes off quicker.
38,741
If gerty's cure doesn't work, you could add a 240Vac relay with coil connected to the power supply 240Vac input, and its NO contacts in series with the speaker protection board.
