+12 Volt DC to -12 Volt DC
kavin6995
Joined Jul 9, 2018
11
I am testing a project in that i have to convert or seperate +12v battery voltage into +12v and -12v... If there is any device or IC for it please suggest.
Thanks.
kavin6995
Joined Jul 9, 2018
11
Another one important thing here i am hoing to give the -12 and +12 as a pulse for 2 devices in a single time throught the battery
kavin6995
Joined Jul 9, 2018
11
I am going to install two devices in a car.. one device needs +ve pulse and second need -ve pulse.. for the pulses i am going to take supply from the battery... For giving pulses i will fix a single push button in the car... if i press the push button both the device should get the pulses.
ericgibbs
Joined Jan 29, 2010
21,439
Why don't you use the 12V car battery as the +12V pulse source and purchase an isolated +12Vby to -12V converter for the -12V pulse.?
ericgibbs
Joined Jan 29, 2010
21,439
hi,
The problem is to convert from an isolated +12V to a -12V at say 2Amps will require additional circuitry, not just the switcher IC.
You can buy ready built modules from eBay etc... I will check it out and post.
E
