115v 1ph 11.5 amp blower motor, j18030650 , wire diagram
rdrausch
Joined Feb 17, 2023
I have a blower motor w/o wiring diagrams. Searching the data on this motor provided no helpful info. Can anyone help me with the wire info? Goodman out of Texas was of no help. I am located in Orl Fl and welcome any advice that will help me with a salution.
LowQCab
Joined Nov 6, 2012
5,102
What is the Motor out of ?
Residential Air-Conditioning / Furnace Blower-Motors are
semi/sorta/kinda/quasi-standardized as far as Wiring-Color-Coding goes.
You might try researching any info You can find on
common brands and see how much of it matches-up with what you've got.
If You have 2 Wires of the same Color, that will usually be the Start-Capacitor connections.
You will need a Start-Capacitor that has a Value similar to other
Blower-Motors that are rated at a similar Current-Range / Horsepower / Voltage.
Usually the Start-Capacitor value is not terribly critical.
rdrausch
Joined Feb 17, 2023
the motor has a controller with 2 plugs, no cap needed but some have low voltage inputs and some do not. I did look at a bunch of diagrams and sadly nothing that has the same numbers. top 4 space plug has a wht and a grn wire, the bottom plug has blk,blu,orn,r,y. This motor came out of a new gas fired air handler. I forgot the model number of this a/h. Maybe Goodman can look up the part number for me. That is where I am heading now. Thanks for the feedback.
rdrausch
Joined Feb 17, 2023
That company is in Air-conditioning ??
As asked, what is the nature of the blower ? size ? AC Volts?
This motor came out of a gas fired a/h, It is 120 volt ac. but the module on the end of the motor has 2 plugs feeding into it. I do not think a cap is needed but dual voltage may be needed to control the motor.
K General Electronics Chat 13
