10 Minute Night Light
Tonydotholm
Joined Jan 9, 2009
1
I want a battery powered night light. Have found circuit diagrams for a couple circuits.
What I don't have is a way to switch Vcc off from entire circuit when 10 minute time is up (output goes low).
The circuit I like so far is one in which a switch applies Vcc to the circuit and a capacitor on pin 2 keeps trigger low so 555 fires. I just need a way to use a momentary push button switch to start Vcc flowing but have Vcc cut off when timer is done.
I don't want circuit using battery power for the 23 hours and 50 minutes the device is not in use.
I was thinking of using a switching transistor (2N2222 NPN) tied to output of 555. When push button is pressed, +Vcc is applied to base of NPN and output of 555. 555 fires and output is high keeping transistor conducting. Once output goes low, transistor cuts off and Vcc no longer flows through transistor.
Any ideas?
Wendy
Joined Mar 24, 2008
23,814
First of all, go with a CMOS 555.
There might be other good ways to do this, such as power down the entire circuit (including the 555) when the 555 goes low.
jj_alukkas
Joined Jan 8, 2009
753
I know a better wayto switch it. But you need an extra component in your circuit. A relay. i had the same problem when I made a water pump timer using 555. I didnt want that thing to run 24hrs after switching the pump off after 5 mts. It might even start the pump automatically after a power failure.
Wire the output from 555 to drive the relay using BC547 (or any driver) and take the output from the relay contacts at N/O to be in series with the 555 Vcc supply. You will need a micro switch across the relay N/O to activate the circuit. I didn't understand your particular application so Im telling from what I understood. Give it a try.
