0 to 5V PWM to 0-10V
Status
Not open for further replies.
daba1955
Joined Apr 27, 2019
218
This might be simple, but I have a PWM signal from an arduino (5V pk to pk) that I want to convert to a 0-10V DC signal.
I'm trying to replicate the signal that a potentiometer with 10V across it would give as the pot is moved.
I think the PWM frequency is quite low, if I remember correctly only a few hundred Hz, I'll check on it and post back.
I'm thinking an R/C network to smooth the PWM, then some sort of voltage doubler circuit, op-amp ??
There's no precision needed, just need to control an existing motor speed controller via the arduino...
TIA
Reloadron
Joined Jan 15, 2015
7,953
The quick and simple turn key solution would be KNACRO PWM-to-voltage module/0% -100% PWM converted to 0-10V voltage. There are dozens of modules available out there to do it. The Arduino Uno just for example uses or has a few PWM frequencies depending on your choice of PWM output pin. The PWM Out frequency can also be changed using code. The PWM output is also a peak voltage and not peak to peak. With a square or rectangular waveform Epk = Eavg = Erms.
You can also, as you mentioned, roll your own Just making a simple low pass filter The drawback is getting a 0 to 10 Volts based on a 0 to 100% PWM having a 5.0 Volt level.
Ron
38,850
Convert to 0-10V DC PWM signal?
I believe the TS wants to convert the 0-5V PWM signal to its average duty-cycle value with a gain of two, giving a 0 to 10Vdc signal.
For that you can use a low-pass filter with a DC gain-of-two amplifier.
The filter frequency and filter order depend upon the allowed voltage ripple, and the response time required for a change in the PWM duty-cycle.
qwertyqwq
Joined Jul 11, 2019
20
you should use an OP AMP which has gain of two. for this application you need minimum 10 V of power supply (or you can use -+5V and a clamper circuit) and low noise materials.
danadak
Joined Mar 10, 2018
4,057
here is a DC sweep of input -
There is a slight offset at LM324 output because it cannot go all the way to ground,
20 mV I believe.
Regards, Dana.
daba1955
Joined Apr 27, 2019
218
Heads up on the OP, originally I wanted a 0 - 10V DC, not PWM. that's because I believed that to be the standard for a motor controller speed control potentiometer. How wrong was I ?!
The motor speed control pot actually only has about 2V DC across it, so replicating the wiper DC voltage with a 0-5V pk-pk PWM signal should be a doddle. Strange controller though, at minimum speed the wiper voltage is 2V, reducing to 0V at maximum speed. That's not a deal-breaker, easily "invert" the control characteristics in code.
So, answering all the relevant posts.....
It wouldn't be a DC signal if it was PWM - I said in the first line of the OP
You believed correctly, crutschow, perhaps you misunderstood the first line of my post, that is exactly what I was originally looking to achieve.
I would not have had 10V available, this all has to work off a 5V dc supply.
Thanks everyone for your contributions, and the time you spent....
danadak
Joined Mar 10, 2018
4,057
To work off 5 V DC supply and generate a 10V DC signal when input is 5V DC
you need to generate a higher V to run the X 2 Opamp circuit in order to keep
a linear relationship between inpujt and output.
You could use a charge pump or boost converter to create the higher DC V needed.
Regards, Dana.
daba1955
Joined Apr 27, 2019
218
Regards, Dana.
I think you missed the beginning of my previous post, I only need to generate 2V dc down to 0V dc from a 5V pk-pk PWN, so all i need is a charge pump, followed by a potential divider.
Since it is a motor speed controller, I don't think it will matter if the RC charge pump doesn't produce a straight-line level, the inertia in the motor will take care of any ripple...
daba1955
Joined Apr 27, 2019
218
One other thought I am having is that since I will only need a bunch of preset speeds, I can use multiple digital outputs on an R-2R ladder network to give me as as many as I need ...
4 outputs = 16 speeds (including stopped)
5 outputs = 32 speeds
etc.
... followed by a 40% voltage divider (5V to 2V) should give me close to what I need
danadak
Joined Mar 10, 2018
4,057
I so do not understand from your original post.
The above says you have a 5V PWM signal, seems to imply you are going to change
its duty cycle to change V, and you later specified 0 - 5V DC which I took to mean the
PWM is filtered and running off 5V hence would vary 0 - 5 V DC at output of filter, and
you wanted that to create 0 - 10V DC.
0 - 5V DC in >> 0 - 10 V DC out
So I am thoroughly confused at this point.....
Regards, Dana.
daba1955
Joined Apr 27, 2019
218
A very nice circuit, posted without any comments whatsoever ...
Please people, I don't need circuits designing any more, my required output voltage is LESS than I have available after smoothing the PWM signal, and I don't need a circuit with 12 or so components to drop it down.
It seems that some people, with good intentions, are not keeping up to date with following the thread, my situation has changed since I started the thread.
daba1955
Joined Apr 27, 2019
218
Regards, Dana.
Please see the above post of mine - the situation has changed from the OP
Status
