lift comp
Status
Not open for further replies.
DexterMccoy
Joined Feb 19, 2014
429
I'm not sure what it is supposed to do, that's why i posted it to see what you guys think it is or what it does
maybe some tech might know what it is or does
DexterMccoy
Joined Feb 19, 2014
429
I don't, the manual just says the input voltage of the very first stage and the output of the very last stage
So I need to know how the circuit i posted works and the theory behind it so I will know what it does
kubeek
Joined Sep 20, 2005
5,796
On some toher shots I saw it was a service manual for some honeywell unit.
Dexter, is your goal to repair that unit, or to learn electronics?
DexterMccoy
Joined Feb 19, 2014
429
See how it converts an AC input voltage into a negative DC voltage
Input is 2 vac , output is negative -.650 Vdc
Input is 5.80vac, output is negative -6.00vdc
Input is 4.00vac, output negative -2.75vdc
profbuxton
Joined Feb 21, 2014
421
Dear Dexter,
If as you suggest you are working on flight electronics I would be interested to know which airlines equipment you are working on. I would make sure I never used that airline.
How anyone can allow you to "play" with such equipment with the apparent lack of knowledge of complex electronics you seem to display is beyond me.
I seriously suggest you need to undertake a comprehensive course in Electronics before being allowed to work on such vital equipment.
Status
